FME Server: DataDownload IP to URL changes
  • May 24, 2016
  • 5 views
sigtill
Forum|alt.badge.img+24
When running a Datadownload internally - for instance from 32.1.10.32/fmeserver the Email with results contains http://32.1.10.32/fmedatadownload/results/FME_12494A5D_1464079512168_3204.zip When running a Datadownload from another external server to the servers external ip (for instance 82.111.12.101) it serves the Email with result: http://82.111.12.101/fmedatadownload/results/FME_12494A5D_1464079512168_3204.zip When looking at Manage - Administration - Services it gives the correct IP (31.1.10.32) - as they always want to use the internal IP - even though the process gets started through the external IP. I thought the Services tab in the webgui was the parameters used also when generating the e-mails? Any workaround to force the internal adress?
todd_davis
Forum|alt.badge.img+22
  • May 25, 2016
