Python: the specified module could not be found
We're getting this error when trying to import a module:
"Using user-specified Python interpreter from C:\\Windows\\System32\\python27.dll
Python version 2.7 successfully loaded
Adding folder `xxxxxxxxxxxxxxxx' to the python path
Emptying factory pipeline
Python Exception <ImportError>: DLL load failed: The specified module could not be found.
Error executing string `import fme
import fmeobjects
import arcpy
import lxml
import sys
#sys.path.append('C:\\Python27\\ArcGIS10.3\\Lib\\site-packages\\lxml')
from lxml import etree
It is okay when I just have: import lxml
We've imported lxml using a Windows exe to the version of Python in the registry which is: C:\\Python27\\ArcGIS10.3
When using this version of Python outside of FME it works fine: we can do 'import lxml' and also 'from lxml import etree'
I've tried adding the path to the module to the end of the PYTHONPATH environment variable.
steveatsafe
Forum|alt.badge.img+12
  • January 16, 2017
What version of FME are you using?  If you are on FME 2016 try doing this before the 'import arcpy'.
import sys
sys.path.append(sys.path.pop(0))
Also see this discussion: https://knowledge.safe.com/questions/38010/arcgis-workspaces-in-fme.html
Hi Steve,
Thanks for your reply. We have FME 2015 and FME 2016 installed on the machine, the 32-bit and 64-bit versions for both.
I've since realised that FME 2016 64-bit is working okay but none of the other versions. I've checked our PATH environment variable and the various FME installs appear in this order:
C:\\Program Files (x86)\\FME\\; (FME 2015)
C:\\Program Files\\FME\\; (FME 2015)
C:\\Program Files\\FME2016\\;
C:\\Program Files (x86)\\FME2016\\
Thanks,
Peter.
