Attribute value replacing with values from another data table attribute
Hi guys,
I'm stuck with one problem and looking for advice. I have two CSV tables. I'm trying to replace attribute values from first table with ones from second table. Let me try to summarize...
Table no. 1
Parcel number Use of land
1 101
2 101
3 201
3 210
Table no. 2
Use of land Description
101 House
201 Business building
210 Church
So, first table is organized by parcel number and there can be multiple uses of land. There is a more than thousand features in this table. The second table just adds description to the use of land identifier (house for 101 etc.) and has 103 different features.
I need to replace Use of land attribute values in first table with Description attribute values from second table so the first table looks like:
1 House
2 House
3 Business building
3 Church
I've tried attribute creator with conditional value assining, feature merger and nothing worked so far. I get empty values for Use of land attribute. Hope someone can help. Thanks in advance.
Best regards
JJ
  • June 26, 2017
Hi @jjaksic22, I think the general approach is: firstly merge the "Description" from the second table to the first table using "Use of land" as join key, then rename "Description" to "Use of land". Take a look at the FeatureMerger and the AttributeRenamer.
Alternatively, the DatabaseJoiner (called Joiner in 2016 and earlier) or the InlineQuerier can also be used instead of the FeatureMerger.
  • June 26, 2017
Thanks @takashi,
it worked with feature merger as you explained.
Best regards
Forum|alt.badge.img+35
  • June 26, 2017
If you have your second table as csv or similar, and it is fixed/constant you could also use an AttributeValueMapper, using the import function to load the values you want to map.
The FeatureMerger makes it easier to manage the mapping externally however.
