Is there a way to get a list of a pointcloud components (not in inspector only)?
  • February 24, 2020
  • 6 views
antoine
There is no PointCloud element in the Python API and I can't find any function or factory to do it. Has anyone found a way (apart from parsing the log)?
Best answer by takashi
Hi @antoine, I don't think there is a direct way to do that, but you can check existence of each component with the PointCloudPropertyExtractor. Hopefully it could be a workaround.
  • February 24, 2020
