Is there an equivalent to Raster Calculator in FME? I am aware of the RasterCellValueCalculator transformer, and the custom made NDVI transformer, but is there also a single transformer to calculate the results of multiple rasters (more than 2) and/or to apply a custom function on these rasters? And, since the Rasters have to be perfectly overlapping, is there also a transformer to reproject and resample an existing raster so that it will copy the properties of the other raster?
Or do I need multiple RasterCellValueCalculator transformers behind one another to get the same result? This somehow does not seem very efficient.
