Aggregator
  • September 6, 2013
  • 14 views
When I aggragate multiple features into one I lose all the attribute data from the original features. Is there a way to aggragate the features, but not all the data? I am working with mulitpatch features in Arcscene.
Thank you in advance for your time,
-Adam
Best answer by fmelizard
You can set the: keep input attributes to yes to keep the original attributes and fill in a list name to conserve all the original attributes in a list form (if wanted).
If there are attributes that are not necessary you can either remove them (attribute remover) or keep the ones you are interested about (attribute keeper) before aggregation.
Hope this helps,
Itay
fmelizard
Forum|alt.badge.img+17
  • September 6, 2013
Hope this helps,
Itay
