How to capitalize first letter in string and leave the rest of string as is?
Hello,
I'm looking for a way to capitalize the first letter of a string but leave the rest of the string untouched.
I have tried the StringCaseChanger, but that didn't seem to yield the result I was looking for. Have Want de Gouden Draak De Gouden Draak het Rijksmuseum Het Rijksmuseum paleis op de Dam Paleis op de Dam
Thanks,
Ed
Forum|alt.badge.img+19
  • March 7, 2018
Hi @edhere, split the input string into the first character and the rest part, change the first character to uppercase, then concatenate them. The SubstringExtractor, the StringCaseChanger, and the StringConcatenator might help you.
Alternatively this string expression could also work as well.
@UpperCase(@Substring(@Value(_text),0,1))@Substring(@Value(_text),1)
fmelizard
Forum|alt.badge.img+17
  • March 7, 2018
Hi @edhere Or with a TclCaller:
return [string toupper [FME_GetAttribute _text] 0 0]
  • March 7, 2018
Hi guys,
Thanks for the comments, I couldn't get above solutions to work so I used below. Seems to do the trick as well.
But a shorter version would be nice of course!
@takashi - Where would I put:
In an AttributeManager?
@DanAtSafe - I'm not familiar with the TclCaller, can you perhaps show me how the transformer should look with the code?
  • March 7, 2018
Scripting. I tried other languages, but probably the Tcl expression could be most concise.
JavaScript (JavaScriptCaller)
var t = fme_get_attribute('_text');
fme_set_attribute('_result', t.replace(/^./, t.charAt(0).toUpperCase()));
XQuery (XMLXQueryExtractor)
let $t := fme:get-attribute("_text")
return fn:replace($t'^.', fn:upper-case(fn:substring($t,1,1)))
edhere wrote:
Hi guys,
Hi Ed, I think it should be like:
  • March 7, 2018
edhere wrote:
Hi guys,
The string expression is just an alternative. You can set the expression to the Attribute Value column in an AttributeManager or AttributeCreator.
However, if you got your desired result from those transformers, no need to use the expression.
  • March 7, 2018
edhere wrote:
Hi guys,
If you are interested in Tcl, try this.
