ArcGISAutomagicSystemDocumenterPortal
  • September 30, 2024
  • 0 replies
  • 11 views
fmelizard
Forum|alt.badge.img+18
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
Uses the ArcGIS for Python API to get information for different item types (currently supported: Layers, WebMaps/Scenes, Web mapping applications, Experiences, Dashboards and Story maps).
It outputs metadata for each item and also the connections between items. The AllPortalItems output port outputs one feature per unique item. The other output ports outputs one unique feature per Portal item ID and connection. For example, a Web Map using 3 services will be output as 3 features in the Web Map output port.
Each item type is meant to be used as input for the ArcGISAutomagicDocumenterReportGenerator.
This transfomer is part of the ArcGISAutomagicDocumenter series. It is meant to be used together with the other transformers, but it can also be used on is own.
Sample workflow for the ArcGISAutomagicDocumenter series can be found here
Would you like to know more? Click here to find out more details!
