,How to specify arabic name to gdb
  • December 8, 2015
  • 10 views
I have a writer which writes a GDB at specified path. This writer has user input parameter as GDB name. When user specifies the GDB name in Arabic it gives me jargon
Forum|alt.badge.img+49
According to the Advanced training material, if you use a Text (Multiline) parameter instead of a Text one it should allow encoded characters. The sample shown in the manual is Chinese but I would imagine Arabic would work too.
