Released
Set Excel Template Sheet in Feature Type Properties
Related products:Integrations
  • February 24, 2016
  • 7 replies
  • 19 views
lars_de_vries
I have an Excel file with different template sheets within one file. Now I can only set one template sheet in the writer parameters. It would be nice to have the option to set the template sheet on the feature type level (e.g. in the feature type properties) in stead of applying it to the whole writer
fmelizard
Forum|alt.badge.img+17
  • February 25, 2016
@takashi
has suggested this a while back. Makes good sense. Tracked as our PR 68141.
Forum|alt.badge.img+19
  • February 25, 2016
yup, the current Excel reader/writer have become much powerful than before, but I think there still is a room to do further enhancements. Thanks for your consideration!
Forum|alt.badge.img+31
  • January 24, 2019
I really could use this today!
  • March 14, 2019
Yes, this would be very helpful.
  • February 1, 2020
Anew...
The template functionality in the Excel writer is great, but I think it would be more powerful and flexible if the Template Sheet parameter would be added as a Feature Type parameter so that you can select a template sheet optionally for each destination feature type in order to:
- apply any template sheet in the template file to any destination sheets (one or more) with different sheet name
- remove sheets existing in the template file but unused in any destination feature types from the destination Excel file
- more?
gogopotter90
Forum|alt.badge.img+13
  • February 9, 2020
this would be very useful.
LizAtSafe
Forum|alt.badge.img+15
  • October 8, 2024
OpenReleased
