MS Word Writer Issue - Creating corrupt documents when writing more than two images.
  • May 5, 2023
  • 16 views
mpsims
Forum|alt.badge.img+8
I am creating PDF reports from ArcGIS Portal Features w/ attachments. The workbench is set up to write to a word doc to use the template doc functionality (custom header/footer) and then converting to PDFs with a PythonCaller. It seems that when writing more than 2 images (from the feature attachments) to the MS Word document, it corrupts the file. Two images or less works correctly and the documents are able to convert.
I am writing out images from attachments to a local drive using the BinaryDecoder and AttributeFileWriter. Then specifying them for the word doc using the MSWordStyler --> Image Source = From File.
I've tried using a PythonCaller after the the AttributeFileWriter to compress the images (jpeg and png) and resize them before being written to the word doc, but that doesn't seem to help.
Any help/ideas would be appreciated.
caracadrian
Forum|alt.badge.img+23
  • May 8, 2023
MSWord and MSExcel writers both have bugs when using templates.
Please run the workspace without a template set and see if it solves the problem.
For MSExcel I found that FME 2021.2 works with fewer bugs.
