Using workspace with disabled connector and transformer in an Automation
  • July 17, 2023
  • 9 views
vxn43
Forum|alt.badge.img+18
I need to publish a workspace into FME Server that has a disabled connector and disabled transformer. In FME Desktop 2021, the workspace can run successfully with these disabled. If I publish this workspace to FME Server 2021 and create/run an Automation, will FME Server recognize the disabled connector and transformer and not run them?
Best answer by hkingsbury
Yes, FME Flow (Server) will recognise you have disabled transformers/connections
hkingsbury
Forum|alt.badge.img+54
  • July 17, 2023
