New to Geometry Validator Transformer
  • October 20, 2021
  • 17 views
Hello there, I really have a hard time to understand how to use the "Geometry Validator". I checked the "help" and still not sure how it works.
I checked an example in IMDF validator and not sure what is the column of "Issue to detect" does, such as "contains -0, NaN, or infinity".
I really hope someone can give me a light introduction on this transformer.
Thank you and I am really appreciate your help.
999
caracadrian
Forum|alt.badge.img+23
  • October 20, 2021
I use Contains -0, NaN, or Infinity to check for invalid measures.
If you use the default Don't Process Measure it probably checks for those values in vertex values of geometries. But I don't use it that often so don't rely on my answer for this case.
