How to delete a published workspace?
lorinda
Hi, I have two published workspaces that I want to delete - changes made and name of workspace changed. Don't want to confuse anyone down the road that may be needing to update the server automations. I haven't found any place to remove published workspaces. Any pointers? Right now, at 2019.1; will be upgrading to 2021.0.1 very soon.
Thanks!
Lorinda
Best answer by nielsgerrits
Login to FME Server, go to Repositories and select the Repository you are looking for. Select the checkbox of the workspace you want to remove and click "Remove".
nielsgerrits
  • June 22, 2021
lorinda
  • June 22, 2021
Ah, silly me, I was looking in the wrong repository. 😏 I found it in the other repository that I had forgotten that I published it to. Thanks!
