How could I read map service by Fme
gogopotter90
Forum|alt.badge.img+13
Hello ,
i am using Esri feature service reader to read map service
but it does not work with me .
when I click on layer to show them ,it is written that token error ,499 error
i have admin user and keyword but it does not work to access .
could someone advice me ,how could I read map service from ArcGis server ?
Best answer by danminneyatsaf
gogopotter90 wrote:
Yes.i did it the correct user for admin and password but it does not work .
should I generate token in map services then use it later to log in ?
You could try using a EsriOnlineTokenGetter to grab a token using your credentials then using the token you received in a FeatureReader to read the Esri ArcGIS Server Feature Service.
hkingsbury
Forum|alt.badge.img+54
  • May 1, 2023
under the reader parameters, have you set the username and password?
gogopotter90
  • May 1, 2023
danminneyatsaf
Forum|alt.badge.img+12
