Open
Raster cell support in fmeobjects
Related products:Transformers
siennaatsafe
jdh
tcrossman
+11
  • siennaatsafe
    siennaatsafe
  • david_r
  • takashi
  • jdh
    jdh
  • tcrossman
    tcrossman
  • geosander
    geosander
  • olivier
    olivier
  • paalped
    paalped
  • safer
  • mattias
    mattias
  • geolassi
    geolassi
  • crayxt
  • scyphers
    scyphers
  • richardjansen
    richardjansen
  • petri
    petri
  • dagw
The possibility to get/set individual raster cell values using the Python fmeobjects library. This would make it possible to perform e.g. advanced linear regression analysis that isn't already supported by the RasterCellValueCalculator.
Exploding the raster into points using the RasterCellCoercer isn't a good alternative for larger raster datasets because of the large memory footprint.
Be the first to reply!
