Is it possible to edit the metadata on a published webservice on ArcGIS Online?
  • October 27, 2020
  • 19 views
Hi everyone,
I want to update the metadata on ArcGIS Online. Is this possible?
This was previously asked a few years ago but I cannot find anything more recent https://community.safe.com/s/question/0D54Q000080hFh4SAE/writing-metadata-to-arcgis-online
Thanks
  • October 27, 2020
@liskett162​  FME Feature Service readers and writers do not support metadata. Please vote on the Idea here. You should be able to read & write Feature Service metadata using the Feature Service REST API with the FME HTTPCaller transformer.
I've attached a small workspace example based on the Esri REST API docs that reads the metadata
