FME 2020: Which tool can be performed to display where the lines overlaps (duplicates) are,
jamal
Forum|alt.badge.img+5
I couldn’t figure out Which tool can be performed to display where the lines overlaps (duplicates) are.
For example, in the screenshot below, there are 4 lines and overlapped in the place marked in orange. How this overlap can be displayed?
the data is attached
Clip_229Clip_230
hkingsbury
Forum|alt.badge.img+51
  • January 24, 2021
SpatialRelator/SpatialFilter will be able to identify them assuming they actually touch/overlap. Otherwise another trnasformer to look at would be the NeighbourFinder
jamal
  • January 24, 2021
Thank you hkingsbury.
But how to perform this two while they require two inputs? I need to catch the duplicates within same “layer”?
Clip_257
Clip_256
hkingsbury
  • January 24, 2021
Clip_257
Clip_256
Pass the same data to both inputs
jamal
  • January 24, 2021
Thank you.
It appears that this tool doesn’t show here the overlap (duplicate) is. Am I right?
Clip_262
