TEXT x-y offset
Text x - y offset   when I migrate text that uses point to for location to arcgis enterpise geodatabase (annotation)
I notice the text will never be at the same position because annotation has a box and the text is contain in that box.
may I know how do I remove the margin?
Be the first to reply!
