Script Generation for Translation
Hi Folks,
I am new to the FME Desktop. I would like to ask if there is a way to export / generate the script after I have defined the detail of my translation in workbench? For instance, the script of the parameter, reader & writer configuration and the transformer used. Is there any method to achieve this?
If yes, then I can customize it based on the generated sample script.
Thanks in advance for your advices.
davideagle
Forum|alt.badge.img+21
  • January 30, 2013
Hi Cliff - Assuming I understand you correctly... the *.FMW file you create with FME is human readable. Just open it in a text editor and you'll see the Readers/Writers as well as the Transformers defined in the code. It's not pretty, but it might help you.
  • January 30, 2013
And just for the record: you can also select individual transformers and readers/writers within your workbench and press Ctrl+C. After that, you can paste this in notepad and you're able to see the code behind it.
  • January 31, 2013
Thank you for your advices. This is useful to me.
