rest api v2 vs v3 compatibility
  • July 23, 2019
  • 11 views
Hello,
We were using fme server 2016. Now we moved to 2019. We tried it with FME REST API v 3 and it works great but my question is:
Is FME 2019 compatible with FME REST API v2? Can I communicate wit hfme 2019 using rest v2?
Thanks for help with that.
Best answer by david_r
As far as I know, there are no plans of deprecating the v2 of the API, so yes, you can still use it with FME Server 2019.
  • July 23, 2019
