A customer who is using FME to connect to our recently upgraded database is reporting that a process for pulling data that was working before the upgrade now seems to just hang after a few minutes. We have SQLNET.EXPIRE_TIME=4 in the server's sqlnet.ora which means we check for dead sessions at 4 minutes. The FME log does not report any errors. It just stops logging and performs no more work.
@dmallard, you may wish to see if the timeout works on the Server side. I'm wondering if the process is getting disconnected.
See: https://knowledge.safe.com/questions/46477/oracle-12c-bad-packet-error-resolution.html
Let us know if you resolved this some other way.
Regards,
Steve
