Workspace doens't work on FME Server
  • November 14, 2013
  • 14 views
Hello!
I 've got a workspace that runs properly if I use FME Desktop, but  it doesn't work if I use it at FME Server. I get following error message:
The clause
'REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE ValueZUSO_ID ValueZUSO_ID'
 within
 'FACTORY_DEF * ReferenceFactory FACTORY_NAME FeatureMerger INPUT REFERENCER FEATURE_TYPE AttributeCreator_OUTPUT INPUT REFERENCEE FEATURE_TYPE TIM.TIM_REO REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE ValueZUSO_ID ValueZUSO_ID MERGE_ATTRIBUTES Yes MANAGE_FME_TYPE Yes MODE COMPLETE PROCESS_DUPLICATE_REFERENCEES No OUTPUT COMPLETE FEATURE_TYPE FeatureMerger_MERGED'
 is incorrect. Only one value can follow REFERENCE_INFO
I'll supsect that the featuremerger doesn't work porperly. The problem appeared using different Service Packs with Version 13, but it also remains if both the workspace and FME Server have the same Service Pack (Version 13, SP1 - Build 13450).
Thank you for your answers
Isabell
  • November 14, 2013
I suggest you send the workspace in to Safe support for analysis.
David
  • November 14, 2013
Ok, I will send the workspace to the support of Conterra.
Regards
Isabell
fmelizard
Forum|alt.badge.img+18
  • July 7, 2014
I have the same problem with Feature Merger in FME Server 2013 SP1
  • November 13, 2014
Hello Julien!
Sorry that I'm answering that late (but I just recently started working again).
You have to care that installed Service Packs are the same on Desktop and Server Installation!
Isabell
