Sentinel2 cloud cover
  • March 19, 2021
  • 7 views
oliver.morris
Forum|alt.badge.img+12
Total novice question when it comes to the Sentinel dataset - I am using the Sentinel 2 open access dataset, trying to play around with getting vegetation index calculations, I am wondering what the easiest way to clip the raster output to remove cloud cover. Which band should I use to identify cloud cover and is there a vector polygon that is already available in open access with this data?
Thank you very much for your help and have a good weekend.
Oliver
oliver.morris
  • March 19, 2021
little digging I found the cloud msk layer, all good.
