Dimension element
  • September 23, 2016
  • 8 views
Hi ,
I'm converting from Microstation V7 to V8 and I have a problem , the elements type 33 (Dimension element) are separated in diferent elements , Text + Line/s , and not are agruped in a unique element of type 33.
thanks in advanced for your help ....!!!
pratap
Forum|alt.badge.img+11
Could you please upload the sample file for review?
Hi pratap , I can't upload the files with the that I work , but I will upload a sample jpg with this type of element , is the element with the red circle.
With this is enough pratap ???.
Thanks for your help !!
pratap
  • September 26, 2016
DGN files have alot of settings which cannot be established with screenshot. So remove all the rest of the features and place only 1 dimension for review.
Hi pratap ,
I have can do it ... only you have to put the reader as by level or number and it works OK.
