Extract text from string in two different attributes
  • September 12, 2016
  • 78 views
Hello All,
I have excel spreadsheet that contains attributes like
Trackcomment O: from 105 to 160 O: from U to S on 117 O: from U to S on 135 O: from S to U on 144 P: from 101 to 111OT O: from U to S on 146BD
I want to create two new attributes (Columns) that contain middle part of the string (105 or U to S or S to U) and end of a string (160 or 111OT or 146BD) in two different excel columns (Attributes).
I am facing two challenges. I used stringsearcher that extracts the last number of trackcomments but missing if there is any alpha character and the second stringsearcher just extracts if it is U to S or S to U but it is missing if the middle part has a number. Please see the attached screenshot. I would appreciate the help.
GGoraya
Best answer by itay
Hi @gsgoraya,
One way to do it is using attribute splitters, since the catch is the varation in the data, so I basically make it equal and then apply the same logic.
Hope this helps,
Itayextract-text-from-string-in-two-different-attribut.fmw
itay
Forum|alt.badge.img+17
Hi @gsgoraya,
Hope this helps,
itay wrote:
Hi @gsgoraya,
Hope this helps,
Thank you for your help. It works.
GGoraya
  • September 13, 2016
GGoraya
Hi @gsgoraya, an excellent solution has been provided already by Itay, but I still think that the StringSearcher may be an option in this case. e.g.
Regular Expression:
from\s+(.+)\s+[^\s]+\s+([^\s]+)$
FYI.
itay
  • September 14, 2016
Regular Expression:
FYI.
Hi @takashi excellent alternative!
I am always hesitant to use the string searcher because of possible data variations and therefore the solution robustness.
