Access JSON URL in attribute
dms2
Forum|alt.badge.img+11
I'm very new with FME and there's a few things I cannot get to work.
I have a feature with an URL as an attribute and it's like this:
http://serverName//document?searchText="section3"&start;=1&max;=1&f;=pjson
I want to read the JSON in it with it's attributes (which I don't know) separated to do something with them.
I've been playing with some JSON transformers like JSONFlattener and so on, but I can't get the JSON.
Any idea?
Best answer by david_r
You can use the HTTPCaller to read the JSON from the server and return it in an attribute.
You can then use the JSONFlattener or JSONFragmenter on that attribute to convert the JSON document to FME attributes.
If you need a more specific answer, please consider posting some sample JSON here.
  • March 13, 2018
dms2
  • March 15, 2018
That's it. I'm learning so much of you help guys. Thanks!
