Convert minus z values to positive (without changing the number)
  • October 20, 2017
  • 8 replies
  • 200 views
Hello,
I'd like to be able to change, for example a -544.43 meter Z value to 544.43. The z values were generated by a bathymetric software package, so positive Z is down. I realize this is a simple multiply by -1, but I can't get it to work on a .LAS file using the "Offsetter" or coordinate tools. I suspect this should be an easy fix, so any help would be appreciated.
Best answer by takashi
Hi @jimmy, the 3DAffiner might help you.
Forum|alt.badge.img+31
  • October 20, 2017
Are your geometries just points?
Forum|alt.badge.img+19
  • October 20, 2017
nielsgerrits
Learned something new today!
  • October 20, 2017
Hi Takashi,
Thanks!!! That worked perfectly. I hadn't thought of using the 3dAffiner. Exactly what I was looking for! Yes, the geometries are all points, so inputting a LAS and outputting a LAS worked. I very much appreciate the help!
  • October 20, 2017
A coordinate replace should also work for point values
  • October 20, 2017
This was one of the tests I did and it did not work. It's possible I was not implimenting it correcctly. Thanks!
  • October 20, 2017
This works for point geometries, but probably your input feature has a point cloud geometry. If so, this could work once you have decomposed the point cloud into individual points with the PointCloudCoercer (Output Geometry: Individual Points). You can re-build a point cloud from the individual points with a PointCloudCombiner after replacing z-coordinate.
  • October 20, 2017
The Scaler works as well.
