I'm trying to configure a new desktop for use with FMe Desktop and other software and i'm trying to figure out if FME Desktop gets any benefit from multi core processors and if so how many cores is recommended, i'm trying to decide between an 14 core I9 and an 8 core I7 specifically. There will be other software running simultaneously(Microstation V8I for example) but if FME won't go any faster with more cores then the I9 will be overkill.
The technical requirements are not really helpfull for this as far as i could tell.
