Pass table name to FEATUREREADER
  • January 28, 2015
  • 23 views
Hello,
Is it possible to pass table name to FEATUREREADER transformer may be as parameter or by any other way.
John
fmelizard
Forum|alt.badge.img+17
  • January 28, 2015
Yes with FME2015.0 it is possible.
gio
Forum|alt.badge.img+15
  • January 28, 2015
in 2014 version you can of  use SQLCreator to read and query usertables, select some (push to a list if multiple) and then connect this to a SQLExecutor to read the tables.
Your SQL will exist partly of attributes.
