Job on FME Server is failing with log giving errors related to Factory
  • November 3, 2016
  • 33 views
fmelizard
Forum|alt.badge.img+17
Here is the sort of thing I am seeing in the job log:
ERROR |The clause 'FACTORY_NAME Router and Unexpected Input Remover COMMAND_PARM_EVALUATION SINGLE_PASS MULTI_READER_KEYWORD ARCGISFEATURES_1' within 'FACTORY_DEF * RoutingFactory FACTORY_NAME Router and Unexpected Input Remover COMMAND_PARM_EVALUATION SINGLE_PASS MULTI_READER_KEYWORD ARCGISFEATURES_1 INPUT FEATURE_TYPE * ROUTE ARCGISFEATURES ARCGISFEATURES_1::CURRENT TO FME_GENERIC ::CURRENT ALIAS_GEOMETRY MERGE_INPUT Yes OUTPUT ROUTED FEATURE_TYPE *' is incorrect. It must look like: FACTORY_NAME <name>
Note that I am creating the workspace in FME 2016 and running it from FME Server 2015. Does that matter?
fmelizard
  • November 3, 2016
Ahh, yes. Sorry to say that workspaces created in a newer version of FME will most likely not work on an older version of FME Server. For sure we can't support this case.
In general, you will be okay with an upgrade within the same major version. For example, FME Desktop 2016.1 and FME Server 2016.0.
Definitely FME Desktop 2016.0 and FME Server 2015.0 is likely to have problems and is not supported.
