I found that removing multiinput and reattaching it wil pass the source attribute described in post.
(on change in the custom..and its gone again)
Generaly i think custumtransformers have a hard time when used mutliple times or with multi object inputs.
Linking and unlinking ( and in case of multi instance, remove and re-add) seems to set it straight, as long as u don't do some changing in the custom..
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
