Plans for adopting PROJ.5 ?
Hello Safe,
PROJ.5 has just been released, and it seems to be a great improvement to PROJ.4.
It looks like all manner of "difficult" projection will be supported (with polynomials and Helmert), so is Safe planning to take advantage of this, and implement PROJ.5 support e.g. in the next major release ?
I know for a fact, that Danish legacy projections will be implemented shortly (if not already), with full accuracy, and henceforth will be maintained here. This enables centimeter accuracy in reprojections.
Cheers
Best answer by fmelizard
Only a few hours before you wrote this, we were meeting about this very topic. It does seem that PROJ.5 has leapt forward. I can't promise an exact timeline, but I strongly believe PROJ.5 will find a way into FME, as we continue to improve our support for all common reprojection options. I do feel bad to ask, but would you mind creating an "idea" so we can track the level of enthusiasm?
fmelizard
Forum|alt.badge.img+17
  • March 11, 2018
  • March 13, 2018
Will do :-)
