I'm trying to populate an output attribute field in a file geodatabase with the input sourcedataset_ACAD. Unfortunately, since I'm iterating through a folder my output ends up with pathname\\*.dwg instead of the actual dwg name. Obviously, this works fine when running one dwg at a time, but I have thousands to convert.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
