I am trying time entry from a SQL table to Excel to be imported into our time entry software. I want to create one worksheet that contains all employee entries and then an individual worksheet for each employee in the same workbook. I can get it to do one or the other but not both at the same time. SO far I know if I define the sheet name - Time Entry - I can write all the data to one sheet. Or if I set the sheet name to - Employee Name - I get the individual sheets for each employee. I have tried coping the writer and defining the sheet name both ways but that doesn't work.
Excel Writer
Best answer by erik_jan
You should not copy the writer, but create two feature types on the same writer instead.
One feature type will be called Time_Entry (no spaces allowed as far as I know), one will have the Employee name attribute defining the name of the feature type.
Then write all features to both feature types.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
