xml formatting or encoding
Hi All, i am reading data from a webservice (creator - xml templater - httpCaller) and the data i receive back is not in the format i expected..... Do i need to play with encoding or something else here ?
i have truncated the xml to just a small section included below.
i receive:
  1. <DocumentElement>
  2. <Results_x0020_for_x0020__x0027_Index_x003D_survey_x0026_StreetName_x003D_KASHMIR_x0020_RD_x0026_StreetNo_x003D_31_x0027_>
  3. <Global_x0020_Council_x0020_ID>20060926T154516_3_Rodney</Global_x0020_Council_x0020_ID>
  4. <Asset_x0020_No.>36848</Asset_x0020_No.>
  5. <Contract_x0020_No.>3853</Contract_x0020_No.>
  6. <Contractor>Project Max</Contractor>
  7. <Date_x0020_Inspected>26/09/2006</Date_x0020_Inspected>
  8. <Completion_x0020_Status>IC</Completion_x0020_Status>
i was expecting more like this below , ie without the "_x0020_" etc values
  1. DocumentElement>
  2. <Resultsfor'Index=survey&StreetName;=KASHMIR RD&StreetNo;=31’>
  3. <Global Council ID>20060926T154516_3_Rodney</Global Council ID>
  4. <Asset No.>36848</Asset No.>
  5. <Contract No.>3853</Contract No.>
  7. <Date Inspected>26/09/2006</Date Inspected>
  8. <Completion Status>IC</Completion Status>
Any hints or suggestions on how to remedy this ?
Thanks Steve
Best answer by jdh
Try a StringReplacer
Text to Match: _x00([0-9a-z]*)_
Replacement Text: %\\1
Followed by a TextDecoder with the Encoding Type set to URL (Percent Encoding)
Forum|alt.badge.img+19
  • May 25, 2016
Hi @goatboy, how about using the StringPairReplacer?
Replacement Pairs: _x0020_ " " _x0026_ & _x0027_ ' _x003D_ =
Note: The resulting text will not be a valid XML document any longer. i.e. XML transformers cannot be used to parse that.
  • May 25, 2016
Thanks @takashi  . Any idea why the feed would be coming thru with these codes? I am hoping to avoid replacing strings. As you mentioned, i am still keen to use the XML tools to parse the data later in the workbench.
jdh
Forum|alt.badge.img+28
  • May 25, 2016
That looks like a variation of hex encoding.
Does your original data come from sharepoint?
  • May 25, 2016
it comes from a amazonaws service i believe
http://ec2-54-252-37-255.ap-southeast-2.compute.amazonaws.com/ImportService.asmx
steve
jdh
  • May 25, 2016
  • May 25, 2016
Many Thanks JDH, i will give that a try and report back.
Steve
  • May 25, 2016
Many Thanks JDH, that seemed to work. i still am wondering why it came thru like that but thats a question for another day.....
Thanks Again
Steve
jdh
  • May 25, 2016
Steve
I actually changed my mind.
I prefer
_x([0-9a-z]*)_
U+\\1
With the textDecoder set to Unicode Code Point
It covers the non latin characters better.
