FME Server Architecture/Best Practices
andrew_r
Does anyone have recommendations on training or white papers that go over the requirements and best practices for FME Server architecture? Looks like the training classes are geared towards building workspaces.
  • July 6, 2016
I recommend reading the first two chapters of the documentation, it's pretty good and it explains a lot of the concepts, it also gives good recommendations. There is also the chapter "FME Server architecture" that goes into quite a lot of detail.
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/Common/Home.htm
fmelizard
Forum|alt.badge.img+18
  • July 7, 2016
Here is a brief guide for producing an Optimized Enterprise Deployment of FME Server:
2016fmeserveroptimizeddeploymentguide.pdf
Many customers start simple and then decide on more sophisticated architectures later. This guide shows what is possible.
helmoet
Forum|alt.badge.img+8
  • August 18, 2017
chriswilson
Forum|alt.badge.img+11
  • August 20, 2017
This should be added to the architecture documentation, if you could please @aaronkoning.
