Plugin FMO Error: 913823
  • December 19, 2017
  • 17 views
anthrax_79
Forum|alt.badge.img+4
I got the below error after running the same workspace that I have been running for months. Any help is appreciated. thanks
Complete Error Message:
"Plugin 'FM0' was loaded, but a reader could not be created. Error was #913823: This format is not supported by this edition of FME"
daveatsafe
Forum|alt.badge.img+19
  • December 19, 2017
Hi @lexadove731,
This error is generated by the Geomedia reader/writer. This writer requires Geomedia to be installed on the same computer as FME, and is usable only by the 32 Windows version of FME.
Have you updated your copy of FME recently, possibly to the 64 bit version?
anthrax_79
  • December 19, 2017
daveatsafe wrote:
Hi @lexadove731,
Thanks Dave. Just now, I did try that again on a different machine with GeoMedia and it worked.
Cheers
