download a feature service from agol
  • August 16, 2017
  • 4 views
angwan
trentatsafe
  • August 16, 2017
Hello @wesleykoros
Are you able to explain exactly what you are trying to accomplish? Judging by the topic tag, you are trying to read from an AGOL feature service to an ArcSDE geodatabase. Is that correct?
If so, you would want to start with an AGOL(ArcGIS Online) Reader. You can set up your AGOL connection through the reader(or can go to Tools > FME Options > Web Connections).
At the end of the translation you would add an ArcSDE writer. In order to use this format you would have to have ArcGIS installed and licensed on your machine. You can then connect to the database using a connection file.
I hope that helps get you started.
