how to select by location and field calculate
  • September 19, 2016
  • 784 views
I wish to replicate the following workflow from ArcMap
1. delete unnecessary fields from dataset table
2. add in new fields and put a default value of "no"
3. Using select by location, filter data that overlaps with another dataset and the field calculate the overlapping polygons with "yes"
I need to do this for 40+ intersecting datasets and am new to FME. I have steps 1 and 2 complete but step 3 has me stumped. I've tried SpatialRelator, Spatial Filter, AreaOnAreaOverlay with no luck.
Best answer by ebygomm
You should be able to use a spatial relator alongside an attributecreator to achieve this.
The polygon layer connects to the requestor port with the data layer connecting to the supplier, then an attribuecreator with a conditional value if _related_candidates > 0 then Field value = "Yes" else "No"
Forum|alt.badge.img+33
thank you, worked great
