Hi All,
I am facing an issue while translating data from Oracle Spatial to ESRI Geodatabase. while translating the data using FME workbench getting error message "Unable to drop the table/feature class 'GD_EXPANSION_JOINT_point'. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {FDO error: -2147216072}". i did google search for this FDO error number but did not find anything. Could anyone help me out in this error.
Thanks in advance.
Thanks & Regards,
Ravi Kumar
