TestFilter not working as expected
  • September 19, 2017
  • 33 views
I have a TestFilter query that works on most dwg layer names but not on a number of layer names.
There are approx 70 Dwg files with approx 300 feature names, most work but one (Tree) does not??
I tried two queries
Else IF @Value(fme_feature_type) IN AF_Tree,G902TREELINE,G902DTREE3,G903TREE_DECIDUOUS,00__TOPO__TREE__LINES,00__TOPO__TREE_CONIFEROUS_SPREAD_SYMBOL
AND
Else IF @Value(fme_feature_type) = AF_Tree
Else IF @Value(fme_feature_type) IN G902TREELINE,G902DTREE3,G903TREE_DECIDUOUS
I keep getting G902DTREE3 rejected into the Unfiltered layer??
Any recommendations would be appreciated.
oscard
Forum|alt.badge.img+21
Does your TestFilter look like this?
I have tried with some data and it's working as expected.
Forum|alt.badge.img+19
first of all, check carefully whether the layer name you have set to the transformer parameter is strictly equal to the actual layer name (i.e. value of "fme_feature_type"). Isn't there a difference in character case? Isn't there an excess leading/trailing space? and so on.
courtney_m
Forum|alt.badge.img+5
Building on @takashi's comment, to ensure to rule out the Case sensitivity, you can test the Upper Case value of the the fme_feature_type - Just make sure your test value is in ALL CAPS - see the screen shot below.
