CORS errors
  • February 13, 2025
  • 31 views
runneals
Forum|alt.badge.img+19
We're sending CORS headers, but not getting them back. How do we get them back?
hkingsbury
Forum|alt.badge.img+51
  • February 16, 2025
What’s the configuration of you CORS settings in the FME Flow UI?
todd_davis
Forum|alt.badge.img+21
  • February 17, 2025
As ​@hkingsbury mentioned, its all to do with your CORS settings and you need to add access-control-allow-origin . It is not in FME Flow's CORS settings by default and sometime it gets used, so is often something you need to add.
runneals
  • February 17, 2025
@todd_davis ​@hkingsbury I’ve explicitly added them, at least I think I did? I also started with the default and started adding things to no luck.
