Error: The log file for job ID "..." does not exist
hermann
Forum|alt.badge.img+10
If I run a workspace manually the FME Server starts logging - but the logs are not available when the jobb is completed:
Jobs ==> completed ==> choose one
"Error: The log file for job ID "..." does not exist"
Any help appreciated. Thanks
Best answer by david_r
It may be that the available disk space is below the critical level, which makes FME Server delete all the job logs immediately after execution.
Check for critical messages in <FMEServerShare>\\resources\\logs\\service\\current\\fmecleanup.log
See also https://docs.safe.com/fme/html/FME_Server_Documentation/WebUI/Configuring-System-Cleanup-Settings.htm
  • June 7, 2021
hermann
  • June 7, 2021
This solved the problem. Thanks.
