how generator snowflake id, use FME desktop, uuid generator result is long
  • May 18, 2023
  • 10 views
charry
Forum|alt.badge.img+5
evieatsafe
  • May 24, 2023
Hi @charry​ if this is what you are referring to, then you might be able to use a word/string and concatenate this with an attribute value resulting from a counter. Example below:imageOr if you know what the specified length should be, you could use a SubstringExtractor and specify the start and end index. Example below:
imageHope this helps!
