I have a GeoDatabase in which roofs and façades are defined by different appearance styles (diffuse color). I used the AppearanceExtractor and AttributeFilter to filter the data. I'd like to produce a CityGML file with the appropriate semantics, but if I connect the AttributeFilter output to the Writer the produced file does not contain any geometry but just the other GDB attributes. Any hints? Thanks
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
