I am working on Win-7, 8Gb, FME-14SP1.
I am generating XML from an MDB input. So, by using XMLTemplater, I have generated a Schema which seems to be quiet long and messy. I just want an auto-check for that schema. (Fig. Attached).
Also, if there are too many WBs with long schemas, it would be much easier to get an auto-check.
I just want to cross check <LANGUAGE> where <NAME> is {name of attribute}.
