PDFSTYLER - URL's exporting corrupt. Pics and Workbench attached.
  • October 23, 2017
  • 6 views
Hello,
I am exporting data from SDE to PDF and would like url's associated with each grid to open a file.
I have created the path for each url within an attribute creator and associated it with the PDFSTYLER.
Here is the "corrupt" url when you click it in the PDF:
Here is the Tooltip showing the proper data for URL (same is used for the URL):
Here is the details within the PDF of the URL box showing it carried over correct:
If you change it opening weblink or opening a file etc etc doesnt change the way it adds all those random symbols in the link when you actually link it.
I will also attach the actual workbench.
This is the version of FME I am using:
Edition: FME Desktop Smallworld Edition (floating)
Version: FME(R) 2016.1.0.1 (20160516 - Build 16494 - WIN32)
Here is the workbench:
Id appreciate ANY help with this.
Thank you!
Savas
Best answer by fmelizard
Hi @sav426,
I'm not sure that this is a bug - The URL isn't corrupt. Those '%' characters are actually related to URL encoding. Check it out here: http://www.degraeve.com/reference/urlencoding.php
%5C represents a backslach and %20 is a space.
 As a test I would try and paste your proper file path into a browser like chrome to see what happens. You may notice that the browser automatically changes the \ to forward slashes and includes a file:// at the beginning of the URL.
Consider changing the AttributeCreator to something more like what you see in the browser - perhaps something more like this:
file:///N:/GIS/MAPS/CL&P;/DETAIL_MAPS/@Value(NAME).pdf
If the N drive is a network drive I would recommend using a UNC path instead of having your path mapped to 'N'.
The other thing which I notice is that for some reason the '&' character is getting dropped. In the site linked above I see that & is equivalent to %26 so perhaps even this would work better:
file:///N:/GIS/MAPS/CL%26P/DETAIL_MAPS/@Value(NAME).pdf
Let us know how you get on
fmelizard
Forum|alt.badge.img+18
  • October 25, 2017
Hi @sav426,
