I'm trying to create a shortest path from point A to B, yet FME is not outputting any path. I've looked at similar questions asked on here, and I've adapted my workbench accordinly, but still no luck.
I'm using an OpenStreetMap highway layer as input. I've explicitely set my snapping tolerance as relatively high in the shortespathfinder, just so that I could just get some output. But it didn't work either.
Printscreen of my workbench:
