Hello,
I created a new coordinate system + transformation based on a grid .gsb file.
While using the Csmapreprojector the transformation fails, can someone help me to figure out the reason ?
Thank you very much.
Here is the transformation I defined
Here is the error I get :
CsmapReprojector_8(TeeFactory): CsmapReprojector_8: Reproject: Could not reproject the geometry of the preceding feature: Reprojector: Could not create reprojection engine
and here is the Csmapreprojector configuration
